Hi Chaps,
I have been reading this article with great interest. I think from you guys` great input I have ALMOST made my mind up!
I currently run a weedeater 2 beam (no bump stops) set as high as I can get without the bottom adjuster stopping the gear linkage working - I did run it lower but rode so harsh (often carry a young family around with me so cant have it too hard!) I have SPAX adjustables and after much shock adjustemtn I still find the ride so choppy over manhole overs and pot holes (in the fens most roads then!) -
At the end of year I wil have some money for dropped spindles - My plan is to raise the weedeater up to say a couple of teeth from max raise - modify the gear linkage so it doesnt rub and then fit some Dropped spindlels (prob T2D as they are just up the road).
I will then probably raise the back up 1 spline to standard and put some horseshoe plates on thus restoring rear suspension to stock "feel".
I am already running 185/60 14 on the front (stock rear) -
Surely the point of spindles is to give stock ride quality with 3.5" drop- (i.e not preloading the torsion bars like you would with adjusters) then it seems the necessity of coil overs to stop rub - does this not then destroy the ride again?
How would you describe the ride with spindles and coil overs compared to say stock? Its a lot of money to shell out for all the bits and pieces if the ride is still compromised? I wonder if I try it with the Spax ajustables 1st before shelling out for coil overs, I just want my bus to sit nice and ride nice - not after extreme slamming or anything like that - after all she does handle a lot better since lowereing!!!
Any feedback would be apreciated!!
