bananacustard
I've just removed my new fuel pump which has failed already twice in approximately 300 miles (mechanichal) to replace with an electronic pump and there is a big puddle of oil under the van which looks like it's come from the push rod tubes and rocker gaskets. These weren't leaking before and the oil smells of petrol. Also the level on the dipstick has gone up.
So
1) Is this most likely to be the fuel pump diaphragm or could it indicate problems with the carbs (34ICTs) ?
2) Obviously I need to do an oil change, how will the petrol in oil have affected the seals (pushrod tubes, rocker gaskets etc)? Will these need changing as well ?
Thanks, Jeremy
So
Thanks, Jeremy
