14.07.2020
Yet again the van is fighting me
Tonight I thought I would finish the steering so removed the pitman arm and centred the steering box - then made sure the wheels are as straight as can be.
Put the pitman arm back on and knocked it back.
Started to tighten the castellated nut goes on so far then goes loose again - so the thread on the steering box is fubared - must have happened when trying to get the pitman arm off.
So, I will have to undo everything and take the steering box out and see about getting the thread redone!
Regards the clutch, removed the spring and took a couple of photos of it so you can pass judgment on it.
Checked everything over again and all seems good, but decided to put the clutch arm thingy on the other way round (which I think is the correct way) - the weight of the pedal is not moving the arm now which is good, but the spring is still not pulling the pedal back up after being depressed.
Starting to get pissed off again……...
