Putting Oil in !
Grazy
Nov 24, 2006
4,619
44
Suffuck
OK so maybe I am being stoopid , but I do find it a real pain to get oil into the filler pipe of my engine , Particuarlly as i use morris oil in a square can with no extendable neck . Any tips / trick you guys use to help me not loose half a litre in my engine bay each time I put oil in :?:
i use a cheap plastic container from a motor factors, has an angled spoute, and a kinda 90 degree top,if that make some kinda sense
otherwise use a small funnel :wink:
I've got a funnel with a flexible screw-on tube on the end from a shop in newquay. Then use a small 1 litre can to fill up with as anything bigger tends to send oil everywhere.
It works dude...you know I have no problem filling my bus with oil :shock:
GSF have a oil jug with an expandable hose which works really well.
The best thing about it is that it has a screw cap on the top and a screw cap on the hose. I can fill it up from the Morris can and tighten up both caps and keep it in the van.
It has really saved me throwing oil all over the engine. :wink:
I use an old skool half pint tin jug, with a proper spout that fits right inside the stock filler. Never use one of those spun alloy aftermarket fillers with the breather, they make it a 100 time harder.
Ive got a pyrex jug stolen from the misses! :shock: :wink:
I use the spill everywhere method :lol: ..............funnel with flexi bit...
...just fitted the wide empi sump was there for hours!!! :x
I just bought a cheap 99p plastic measuring jug but i have used the spill everywhere method before :lol: :lol:
washing up liquid bottle for me....
also have one for the brake fluid... 8)
Go through this link thread.
But I use an old plastic milk bottle.
Nice though
http://www.ssvc.org.uk/phpbb/viewtopic.php?t=39306
The plastic spouted bottle that EP90 axle oil is quite good - i usually spill it when filling the bottle but not in the engine bay. having said that, I just ordered a spouty jug from JK.... :eek:
I use the same but knicked mine out of the kitchen. For some reason she did'nt want it back. :roll:
been looking for something the right size for ages, then I read ".5lt plastic milk bottle" GENIUS!!! the simple things are allways the best :)
