- Joined
- Oct 26, 2010
- Messages
- 3,247
- Reaction score
- 17
- Location
- Leeds
- Year of Your Van(s)
- 1971
- Van Type
- Panel
junglefacejake said:Gutted to hear your woeful first trip tale.![]()
Sounded like extreme symptoms for just a blocked fuel filter.
Hope it all gets sorted
It was a lot more than the fuel filter - that was just the biggest culprit.gninnam said:Great news :mrgreen:
What was it then![]()
There were lots of little bits wrong with the engine that I don't think were helping. Here's a list of some of the bits I've tackled this last couple of weeks:
- First, most obvious thing, was to replace all the fuel lines, fuel filter and clips.
- Rebuilt the carbs and ensured that all galleries were clear and free.
- Both carb bases were banana'd/warped so I flatted/skimmed these so that they now get a proper seal (no more air leak there).
- Speaking of air leaks, the balance pipe ends were perished causing a leak there too.
- New HT leads. The sparkplug end of lead 1 was broken and perished pretty bad (less than half of it left).
- New plugs (set gaps)
- Set valve clearances (they were quite a way out)
- Oil change
- New fanbelt. The one on there was probably okay for a while longer but new one is good and tight and shimmed correctly.
- New dizzy. Got rid of the [apparently rubbish] T25 electronic ignition unit and put in the Accuspark SVDA unit I've had knocking around for over a year
- New (old) fuel pump. It's never good when the barb from the pump comes off with the rubber hosing, so off with the dynamo pump and on with a decent alternator pump that I have "borrowed" from my old engine.
- Bit of a general spruce up (degrease and quick splash of high temp paint to keep the rust at bay on the tinware)
- Straightened and re-welded the moustache bar. Replaced the mounts as one had completely sheared in half!
- Cleaned the [really] dirty air filters
- Fuel regulator put in place (planning ahead for a future electronic fuel pump install)
- New (old) exhaust fitted as the one on there before was too loud.
- ...that's all I can remember right now!
Still to do:
- Double check the electronic chokes on the carb (anyone know how I can test these?)
- Re-fit the air filters
- Get it idling happily
- Test drive
- Get it booked in for a rolling road session with an old-school tuner to get things set up proper
- Enjoi it for a few weeks before sending it off for a little winter work
At least, I hope that's all that's left to do!
I am a little concerned that my fuel pressure might be a little low so might have to source a different push rod (that's all I can think would cause it). Test drive should prove this pretty easily!
