secure heat exchangers open
MMMC
Feb 2, 2007
636
Leeds
Dudes - does anyone know how to secure the heat exchangers open..do I just need some wire? The heat controls are not connected from the front...I just want them secured open for winter. Cheers
I bit of wire will do it there should be a lever on the top of each exchanger at gearbox end, but if you fit a couple of cables it will work all year round :wink:
I fitted new cables because the old ones were seized, but for some reason the lever was still too stiff to move. The level itself moves, when the cable is disconnected, perfectly well. The cable can be pulled and pushed with a pair of pliers when it's not connected to anything. The flap on the heater box moves perfectly well also, on its own. But when I connected everything, I was at risk of snapping (again) the plastic heater control levers (right where they attach to the metal part of the lever, I'm sure you've seen this thing before, seems most every Bay I come across has snapped and rigged plastic bits).
So I just wired open the flaps for the winter, and it worked fine (probably better, since I could ensure that the flaps were REALLY fully open. Then in one spare set of flaps, I screwed them into the fully open position with some screws through the outer housing, so ALL of the hot air came up to the front. This worked very well, and I just swap out the housings when the season changes.)
Cheers, A.
