CornishSilver said:A cracking bus you have, some great pics too
markevo30 said:Exciting times looking forward to see it in paint.
Do you know what the original colour of the bus was?
Bluesnailman said:Thanks for encouragement. I need to get a wiggle on! Need assembly and mot done in 3 weeks for first outing....
Bluesnailman said:Must post some photos.... been to Rutland, Sandringham and North York Moors for weekends so far this year, but without the heater as leaky heat exchanger.
So got the heat exchanger swapped out this week for a modern reproduction unit. Seems a shame as in the last year I've taken out two VW heat exchangers...... Still getting heat through the new ones though, but deep down I know they won't last nor give the same heat output. A lot healthier though.
Engine got a full service this afternoon, with new distributor cap, rotor, oil, valve clearance check/adjust etc. Changed the spark plugs also.
I did a bit of research on them as despite having the right jetting and carb adjustment I was getting some plug fowling.
NGK website has some really good info and so I came up with a plug that should burn off the deposits a little better.
NGK BP6ES. Gapped them up properly, bit of copper-ease, then turned engine by hand to check for interference (They project into chamber a bit more than the Bosch ones sold by our regular VW parts people).
They seem just fine at the moment, will give an update in 3000 miles.
Interestingly I arrived at the same conclusion as these people.... or did they lead me there?
http://vwparts.aircooled.net/NGK-BP6ES-Spark-Plug-14x3-4-Reach-Threads-13-16-p/ng7333.htm
If you drive your van hard with foot to floor a lot then you might not have any current problems, but I'm a 3/4 throttle guy when i'm in the van, so engine doesn't get real hot.
Either way, one thing I sure have learnt is that eBay is a lot cheeper for spark plugs if you know your product code. Now deep down I knew that, but had never bought separately before... (got 8 for £10.56 inc delivery)
