bluenose
I've taken my engine out as had a lot of rattling noise coming from the gear box and the clutch went, looks like some oil contamination on the clutch but can't really see what the rattling is but
If I grab the input shaft I can just pull it out, not all the way as it won't clear the seal but I can slide it in and out 3 inches or so. Is this normal?
I've researched on the net and it looks like to remove them you should have to open the box take off a circlip and unscrew them so I am guessing mine is nackered
