This is a post of what wheels and tyres i'm NOT running on my bay
Today I've been arsing around with wheels. I would like to run something big on the back, a 205 70, but wanted to make sure it would clear before I splashed out. Luckily I have a very friendly tyre place that fitted a used tyre for me to try out. So, jack up the bus, slide the wheel over the studs, and bugger! The offset on my gasburners appears to be completely wrong.
to show what I mean, heres a pic of the stock wheel, and its clearance between it and the spring plate, then the same with the gas burner.
Having previously had one of my 17x7 fusch copies on the back, I thought I'd see if this would still work knowing that it would be tight on the adjustable springplate, but alas not, it fouls big time. If I space it off the drum with a spacer, the studs arent long enough, and the tyre is about the same place as the burner.
So now I have no wheels for my bus! I quickly looked to see if I could get the back of the wheel machine down to change the offset, but to get enough i would completely loose the seating surface for the wheel nuts.
I think I will try and get a stock width tyre on it, a 185, just to see if that will work, but looking at it, I think the tyre wall will still foul on the lip and inner arch
The box is marked up as 'offset 6' which doesnt tie up with MWS current listing which is 'Offset ET20'. I've sent MWS an email, but as I bought them at least 6 years ago for another project, I dont hold out much hope.
Little update, just had a mooch around on the net
http://www.ebay.com/gds/Wheel-Offset-Backspacing-what-it-means-finally-/10000000009860383/g.html" onclick="window.open(this.href);return false;
going by whats written there, and using a couple of steel rules, the difference between the front face to the wheel mounting surface and the back face to the wheel mounting surface is 20 mm, so the ET on my burners is 20, as per the current wheels, so what gives, why cant I get a tyre under there??
