Tyres / Stance Thread - Lets see what ya runnin!
165/50x15 front and 185/65x15 rear link pin beam and spring plates with a bit of chassis notching on both front and back.
This is a before picture prior to fitting some horse shoe plates at the rear new pictures will follow, 165/55 15's front, T2D dropped spindles. 185/65 15's rear, one spline
Im running 175/65/R14 front 175/70/R14 rear. Cut and turned beam. But ive got to go a bit lower (so i can get out of the garage without letting down the tyres and taking off the skylight!) and narrower so im looking into a narrow adjustable beam and some dropped spindles.
Here is mine
Thats for you Sparkywig
2" Narrowed CB Performance Beam , With Adjusters
Dropped Spindles
Adjustable rear springplates
15" Splitty Steel Rims wearing 165/50/15 on front and 185/65/15 on the ass 8)
Previous set-up:
Front: Foksy adjuster on top beam only; Beetle rear shocks (Cofaps); 185/65-15
Rear: 1 spline drop; standard shocks; 185/65-15.
Result = bouncy ride with front tyres farting on wheel arch at every opportunity :(
Current set-up:
Front: Foksy adjuster on top beam and added Albatross adjuster to lower beam; KYB-GR2 shocks; 175/60-15
Rear: as before, 1 spline drop; standard shocks; 185/65-15.
Result = much firmer ride but not too harsh. No more farting :D
Grazy said:
Here is mine
Dropped Spindles
Looking good, great stance 8)
Just
http://s927.photobucket.com/albums/ad112/mychatype3/?action=view&current=P1010213.flv" onclick="window.open(this.href);return false;
This is my 1970 type T2a, Westfalia
Front axle:
- Own build front axle, 5,5cm shorter with 1cm thick end plates, longer shock towers;
- Monroe Air shocks, 15psi = 58 cm road to under arch/ 80psi = 60,5cm, 100psi = 61,5cm;
- Transporterhaus dropped spindels;
- Adjusters in tubes, upper tube lowered with two splines;
- Porsche 944 disk brakes, GolfII servo, Porsche 944 mastercylinder;
- Gasburner wheels brand: JGE, 15inch ET42, 175/65/15 tires, Firestone;
Rear axle:
- Horse Shoe plates, 49 cm road to under arch;
- Porsche 944 disk brakes;
- Spax shocks;
- Gasburner wheels with 195/65/15 tires, Firestone;
Drive
- Great just like original only looking nice, low and smoother :mrgreen:;
- Minimal psi in shocks is 55psi if not the tires will rub the arches (the tires are not low profile)
Greetz Mycha
Do you know what type of BRM's you're running? I've got a set of MWS which I'll be fitting to my '71 before too long and want to fit a decent width tyre without rubbing. Would have to be a profile to match original though so top-speed gearing is correct.
geezerblast said:
175 55 15 front
195 65 15 rear
on mws brm reps 5.5
Great! Bet the 195's were a squeeze under the arch? I've just trial fitted a scrapped 185/65/15 on a MWS BRM 5.5 to see what clearence I've got with a 185...and not much. Engine and gearbox are out at the moment though, so difficult to tell for sure as the tops will tuck in a bit. Those BRM's do have quite a off-set (E6) compared to stock. Did you have trouble with the studs/nuts too...or is it different on a '68? My MWS nuts only go half-way down the studs so I'm looking to get some longer versions.
I'm looking to fit 195/70/15 on the rear of mine (just about as close to the original 185R14C rolling radius as you can get) and 185/65/15 on the front, both Continental Vanco Contact 2 if I can get hold of them (http://www.conti-online.com/generat...co_contact2/vanco_contact2_ps_en,tabNr=3.html)
bit of a squeeze i have about 3mm clearance i;ve still got camping gear to put in so should gaine a bit more
its clearence no less .like you say engine and box will lay the top of the wheel in
studs were the longer type
ps.
when i let the jack down tyre did catch the arch but once it was down it was clear :oops:
Write your reply...
