Having a little trouble with my 68 drum brake bus braking unevenly. It's not too bad and still stops in a timely manner without having to wrestle with the steering wheel, but it's noticeable so it bothers me. It's completely random, sometimes doesn't do it for days and when it does, will pull either right or left. It *might* happen more often when I apply lots of pressure, like going down a very steep hill slowly but I could be mistaken. Once it happens, it's like it's activated and stays uneven for a bit then settles down again.
Have replaced all brake hoses, steering damper, had brakes checked by mechanic (says they look fine), bled system, adjusted brakes, adjusted handbrake, checked tire pressures, replaced master cylinder (was leaking a bit) and am now stumped!
A bit more info:
I have got 15's on rear and 14's on front (about to replace actually so all even) but can't see that bothering it. Only other minor thing is I was never really happy with the steering exactly. Hard to explain but the guys who set up tracking messed up first few attempts ended up with way too much lock on the right and not enough on the left. The steering wheel now doesn't line up and never really seemed centred properly, like the movement was off or something. But again that's very minor and there doesn't seem to be any excessive/uneven wear so I don't think its that.
Any ideas? Cheers
Adam
A bit more info:
Any ideas? Cheers
Adam
