Trikky2
StuF said:Do you have to remove the towbar and rear bumper to install the exhaust? Or is it possible to do without removing them?
Just the valance. Deffo no need to remove the bumper.
StuF said:dormy72 said:Had mine nearly 2yrs now, absolutely fantastic bit of kit and would recommend them to anyone, a doddle to fit and mines runs heat exchangers and van has towbar, no clearance issues.
CHILDSEY said:Have you got the standard tail pipe or hidden one?dormy72 said:Had mine nearly 2yrs now, absolutely fantastic bit of kit and would recommend them to anyone, a doddle to fit and mines runs heat exchangers and van has towbar, no clearance issues.
I've ordered standard version , as prefered look of this one.
Cheers Paul
Trikky2 said:StuF said:Do you have to remove the towbar and rear bumper to install the exhaust? Or is it possible to do without removing them?
sparkywig said:Trikky2 said:StuF said:Do you have to remove the towbar and rear bumper to install the exhaust? Or is it possible to do without removing them?
I can't get my valance off without removing the bumper.
dormy72 said:As mine is a 72 crossover the rear valance can't be removed, I also run twin carbs so no pre heat risers, why do you need to remove the valance?
Bigbear said:Should you receive the small gaskets for the heat risers with the kit?
sparkywig said:dormy72 said:As mine is a 72 crossover the rear valance can't be removed, I also run twin carbs so no pre heat risers, why do you need to remove the valance?
Just for access really, it's a lot easier to reach the exhaust studs and fiddle with the heat exchanger connections over the moustache bar.
If you ordered one with heat risers, then yes.
Max Power said:Thats how I fitted my air hose.If you had a gasket set for the engine the riser gaskets should be with that?
The sound is orgasmic!StuF said:Mine arrived this morning and am fitting it now! Looks awesome!
Max Power said:The sound is orgasmic!StuF said:Mine arrived this morning and am fitting it now! Looks awesome!
