Waxoyl on EarlyBay?
gilbo
Jun 3, 2015
63
Seen some differing opinions on this but need to do something for my Early Bay. Is Waxoyl the way to go or is there a better alternative? Any advise on where I could get something done in the New Forest area?
Nick
For me there is not much difference between the two. If i remember Dinitrol is thinner out of the bottle (so to speak) and requires less or no thinning if you are spraying internal chassis parts etc. Waxoyl can require a lot of thinning prior to spraying. If that is what you are doing.
To be honest they both do a good enough job. As always preparation prior to application of either product is the key to successful under body sealing.
Thanks for the response and the information. Not something I want to do myself so will try and contact a specialist (unless someone knows somebody).
Just got a quote for Waxoyl for £440 including VAT. Includes the following:
The Waxoyl treatment is completed by a fully trained operative, your vehicle will be fully cleaned and prepared prior to its treatment which includes the removal of loose rust to ensure we apply treatment to a solid material. The Waxoyl is applied via compressor to ensure an even and thorough coating.
Takes a day so price doesn't sound too bad - plus there's a 5 year warranty...
I didn't fancy waxoyl as I believe it is tacky and assumed that all sorts of crap would be sticking to it. Dinitrol is top notch stuff, 445 and ML3125 for cavities.
http://forum.earlybay.com/viewtopic.php?f=2&t=52779" onclick="window.open(this.href);return false;
https://dinitrol.co.uk/ClassicCar.aspx" onclick="window.open(this.href);return false;
That's a good point around the stickiness. I've asked the same place for a quote for Dinitrol - it does look preferrable.
Dinitrol is an extra £40 (£480) so think I will probably go with that.
Andy_sheff said:
Ile second dinitrol, far better
3rd Dinitrol
Waxoyl you have to sit in a bucket of boiling water unless its 25c or hotter outside
The brush on stuff will just crack over time and rust even worse underneath
