many thanks for the replyNo, if you do that the parking mechanism will short out term 53 (and therefore live 30) to ground through the wire connected to
term 31b, and blow the fuse if not worse. Heat up terminal 53b instead, which I think is the hi-speed terminal. Wiper motor should run as long as
30 and 53b are connected, assuming wiper motor case is properly grounded.
I guess I should explain what I am trying to achieve as the title is perhaps a little misleading. The wipers seem to not work most of the time, I had them working when I removed the switch from the dash and when I put the switch back in the dash it didnt work again. I have taken the switch out again and checked live and earth and they seem fine so I was thinking how I could logically test the wiper motor by bypassing the switch.In the schematic above, the middle contact at D being connected to term 53 would imply that the cam mechanism
causes it to alternately contact the term 53a wire and the 31b wire, but I think it should rather be the 53a contact in the middle.
Also, the legend for terminal 31b says "Switched Ground to Wiper Switch" whereas it should read "Switched Ground
to Wiper Motor".
Sorry to sound like a idiot but when say connect to a ground - do you mean run a ground from the motor to earth ? And if so where would I attach the ground on the motor?Connect a ground and then put a 12V feed to terminal 53 and then 53b to see if the motor works.
understood, much appreciatedJust unplug the black cable connected to term 53 and tap it on the feed terminal 30 to prove the motor works.
Thanks. I found another wiring diagram that looks to be about the same. Now for getting that puppy out from under the dash, and sourcing a replacement motor if this one turns out to be bad.There's wiring diagrams for both early and late bus wiper motors & switches to be found at the following forum thread:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8956954#8956954According to that, one of my remarks about the accuracy of the diagram posted in the first post of this thread
is mistaken.
