gninnam said:Looking good 8)
How do the endplates work then regards adjusting the camber :?:
Dogo said:Fantastic build. Love it! I also like how you share all the information, kudos.
Nothing outrageous, cosmetically, but some cars just have that " je ne sais quoi". This one definitely has it.
Is your new beam also 5.5cm narrow, or is it more narrow? I would like to emulate your front end setup, but wondering if you feel you would benefit from a narrower beam or is the 5.5cm good enough for rubbing clearance for the 165-55?
ground hugger said:Like the end plate idea 8) what's the hole between the tubes for ?......Dave
With a narrowed beam and new end plates you loose the bumpstop, i drive with air-shocks, when they are deflated the top off my tire is just 1,5cm from the inner archground hugger said:Like the end plate idea 8) what's the hole between the tubes for ?......Dave
ground hugger said:8) good idea with the tyres that close. The air shocks you have fitted only have 75mm of travel (think ive read it right) and the height you travel at only gives you 35mm of downward travel, and 40mm of upward travel/rebound......And it drives spot on
...Do they make a smaller size shock ?....Dave
mychatype3 said:
squareweave said:Wouldn't those adjust caster not camber? Great idea btw!!
mychatype3 said:Dogo said:Fantastic build. Love it! I also like how you share all the information, kudos.
Yes my new beam is also going to be 5,5cm narrowed, with my 944hubs (also 8mm a side) and the 5,5 ET42 fuchs it’s small enough tot clear for rubbing![]()
Greetz mycha
Dogo said:Thanks. Do you foresee any issues with the fit of the air shocks if it were the exact same setup BUT 1 inch narrower on each side? (10cm narrow instead of 5.5cm narrow)
