OK, this is the final treatment of the Westy's undersides. UPOL Raptor Truck Bed Liner. Choose this instead of normal stone chip because, well, it's better! It seems to have many advantages over normal stone chip, and certainly seems a more permanent option. It can be tinted with any colour paint, i went for body colour, much quicker than waiting for stone chip to go off, and then painting with top coat, it only needs a maximum of 10% top coat, just fill, shake and shoot it on. Done, no reactions as you may get with normal stone chip, as the solvents can react and cause the top coat paint not to stick
Got it from here:
http://www.ebay.co.uk/itm/U-pol-Raptor-Tintable-Tough-Urethene-Coating-Truck-Bed-Liner-Kit-Trailers-/110785795320?pt=UK_Body_Shop_Supplies_Paint&hash=item19cb5914f8" onclick="window.open(this.href);return false;
Bob @ Restohaus did the work for me again, I requested to leave the running gear, axle, suspension etc in the black 2 pack coat we used last time, and concentrate the UPOL onto the wheel arches, belly pans and chassis areas, giving a good coverage on the arches and belly pans especially.
Went on really well, got all wheel arches covered, bellypans chassis area, front chassis and bellypan, will need some more to do the rear battery trays, and the middle rectangle where the heat tube goes, with another kit, there would be more than enough, i only really need maybe 2 ltrs max.
Mixed with pearle white, one shot job, better option than stone chip and then top coat. Nice finish, but could be adjusted with more or less gun pressure no doubt. It has "give" in the feel on the surface, a little like wine gums, midget gems, jelly babys, so not a solid coat, this will help resist stone chips and knocks, the colour seems well bonded into the coating, and doesn't seem to crack, though i haven't pressed too hard!
It seems quite thick in the consistency, and may well aid some element of soundproofing according to the spec of the product:
U-pol Raptor Kit - contains 4 x Raptor Tintable & 1 x Activator
U-POL's top-class super-tough durable 2-pack urethane coating against rust, corrosion, salt, damp and extreme temperatures.
Restores even the most worn and uneven truck beds or van floor to new pristine-look finish.
Dries rapidly to give scratch and stain-proof surface that is also U.V. resistant.
High adhesion, waterproof, flexible, helps deaden sound & vibrations.
Easy and quick to use, as simple as: FILL - SHAKE - SHOOT®
Kits contain 4 x 750ml bottles of base and 1 x 1L of hardener - you can add up to 10% solvent basecoat tinter to colour match to the item you are coating
Enough material to re-spray the largest truck beds.
Apply with schutz gun, roller or brush to obtain different textures.
Also available in Black
http://www.u-pol.co.uk/product-cat/83/raptor%E2%84%A2-bed-liner.htm" onclick="window.open(this.href);return false;
Here are some pictures:
On with the next job. Wiring, and new interior wood.......
Alistair
