aogrady
Hi!,
Anyway, was thinking about noise, and soundproofing etc, now, I had already fitted sound deadening stuff on the inner panels as you know. Now when i re-do the wood, I think i will try some more flashing on top of what i used, just to see, I wont need much. Might pull up the floor and use it under the wood, though to be honest, with the thickness of the ply, doubt if it would make much difference.
Now as much as i love the propex, I would like to try and case it, or soundproof in some way, I have a short run from propex to the exit vent, so i think this short run is allowing it to sound noiser than it would be on a long run, so I came across this:
http://www.ductstore.co.uk/acatalog/info-SIL50-300-100.html" onclick="window.open(this.href);return false;
Now, just need to do some measurements, but the dB reduction certainly looks good, unfortunately, I have no idea of what frequency the noise is, or the current dB is.
http://www.ebay.co.uk/itm/30-130dBA-LCD-Digital-Sound-Noise-Level-Meter-Decibel-Pressure-Tester-Monitor-UK/321225147847?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D18223%26meid%3D1927674304134773661%26pid%3D100005%26prg%3D8339%26rk%3D3%26rkt%3D4%26sd%3D271195620541%26" onclick="window.open(this.href);return false;
Not as expensive as i thought. I think a plan might be hatching......
Now i may be tight on space, as i still need to fit the big x2 Trojan deep cycle batteries for the solar panel, but i think i may be able to re-route the pipework around a bit to fit one of the acoustic attenuators
Would quite like to see how loud my motorbike exhaust is running open race cans - I suspect quite a bit more than 110.....I once had a set of open Termignoni's, they were quieter than what I'm running now, I'm not sure my ears could stand it once i get it on the road..
They do sound awesome, but boy, are they loud! I must be getting old...... :character0032:
I'll come back to this a bit later if i use the meter, I thought these links may be of interest to you guys.
Cheers,
Alistair
Cheers,
Alistair
