pistachio
right where do i start? this morning i decided to adjust the valves, as my van is misfiring. removed the distributor cap, turned the engine until the arm pointed at the notch on the case. this pointed at about 2 o'clock not 4 o'clock where it should be. so i removed the spark plug from piston #1. placed a screw driver in the hole and turned the engine until the driver was pushed out and the distributor arm was at 4 o'clock and the notch on the crank shaft pulley was at the top in line with the split in the casing. i then loosened the distributor case and moved it inline with the arm. then adjusted the valves on piston #1, turned the engine counter clockwise 180o, adjusted #2, turned the engine counter clockwise 180o and adjusted #3, turned the engine counter clockwise 180o and adjusted #4.
as i had moved the distributor case the leads were in the wrong order, so i moved them to- bottom right #1 bottom left #4 top left #3 top right #2. put everything back together, turned the key...... nothing! the engine is turning over but wont strike. checked all the leads, nothing :evil:
if anyone has any idea was gone wrong i would be grateful.
thanks dave.
thanks dave.
