Clem said:If I was not as low and on a full width beam, Id run an arb, for sure.
But, none of the above apply! :lol:
Moseley said:I've had mine on order from rally design roughly 5 weeks now. They're hoping to have my set (hopefully they've ordered more than one!) in the next couple of weeks.
jimbope said:Im still interested in this thread as Im on my 2nd set of cheapy coilovers (the bushes go after about a year if you are lucky) and will replace mine with a better quality coilover. - Im running 3.5" flipped spindles and a weedeater 2 beam on a high setting. Dont get much rub but ride is pretty bouncy - even on motorways etc.
Ive just found these and wondered if anyone had used them before as an alternative to the GAz ones?? :?:
http://www.avouk.com/CatalogueFrameset-84.htm
They list the Vw transporter 67-79 part No PB441.
There are no measurements as far as I can see but they are adjustable in both spring rate and damping. 60quid each??
jimbope said:HI Aspro, Thanks for your advise on me buying 2 **** sets - :lol:
The first set was fitted by T2D and the second set was supplied under warranty due to failed bushes - long before this thread happened.
All I was doing was showing people on the forum all the options as it seems some people are struggling to get hold of the GAZ ones and its always good to spread the word!
The AVO ones are actually listed to fit our vehicles off their website..They get some good feedback on other marques.I will call them and find out what the length of the units are and whether they are availible.
67westy said:I'm running with the collar about 10cm up the thread and 6 clicks from minimum.
Let us know how you get on![]()
67westy said:67westy said:I'm running with the collar about 10cm up the thread and 6 clicks from minimum.
Sent from my Nexus 5 using Tapatalk
