bump
Earl Bay said:What do you guys think? Lowering possible via the springs or not? sorry for the long post
Graham L said:With regards to the GAZ Dampers that Adam mentions above I'm happy to share the information with people as the intention was to offer them at a good deal by buying in bulk but couldn't get enough interest to buy them in the right quantity.
I've checked the records this morning and the dampers that have been fitted to Monty (my old 69 Panel Van, Adams (67 Westy) and are currently fitted to my latest bus 'Billy' are GAZ Units 160/105B12, they are fitted from memory with 9" Springs but can double check that, I'm currently running 150lb springs but when Adam had them they where fitted with 125lb springs.
Happy to show people and let people have a go in my bus if it helps, they are 10 times better than the bug pack ones which are off the back of a beetle, are height adjustable within reason, they have never bottomed out (dont get me wrong the beam has hit the floor a few times) but thats due to bad roads rather than the dampers, don't suffer from any wheel arch rub and I won't win slimmer of the year anytime soon :lol: :lol: . Bus is on transporterhaus dropped spindles.
Graham
From your research, did the GAZ dampers appear to be the best solution just for lowered buses, or in your opinion are they the best damper when put against the likes of SPAX, KONI, etc.
I'm finally getting the westy on a weigh bridge tomorrow to see what the full loaded weight is likely to be with half the oak forest that I usually carry in it with the usual camping gear as I'm concerned that standard shocks may not be up to the job, but adjustable ones may be better - unless I am totally on the wrong track :?
Mickey Sam said:like to add my thanks Graham L and to Aspro for starting the thread and 67 Westy, Andy O and all the others who contributed.
OK- 'Oscar 'speech over -,cheers guys, info and advice much appreciated.
Can somebody shed some light on this please:
First of all: Wow!! what an improvement in ride quality, even steering got better.
I need some finetuning hints though:
I'm on dropped spindles and I have adjusters on my beam. I think its a balljoint beam and still running the stock 14" with 185r14. Not quite sure at the moment, but I have sth. like 6 teeth left to go lower .
So I installed some 160/105 with 10inch/150lbs spring. (the pic in the panelvan porn thread is with standard shocks).
The front came up by an inch (maybe a bit more 3cm i think) after installing them. But contrary to the most of you here I'm at 6,5cm from the bottom thread with almost 0 tension on the spring (just barely so it doesnt pop out while letting it get back on its feet). 10cm and it would be ready for takeoff.
So how do I go lower: Can i wind down the spring, say another 2cm? That i figure would mean less travel for the damper itself, combined with the fear the spring could pop out while letting the car back down on its wheels (the way I remember it the thingy on top of the shock that holds the spring in place is fixed and cant move).
Or do i have to lower it via the adjusters on the beam? I'll go lower on the adjusters when i get new tires and rims anyway. But that will have to wait till winter.
Thing is, its just cosmetic at the moment. It rides terrific. No rubbing what so ever. But I have the impression that it has a slight nose up rake (It had a nose down rake before, thats where i want to get back to). Just barely really. I dont have a proper jack at the moment plus I actually wanted to go on holidays tommorrow. If I'm lucky the springs settled a bit during the past week. I've only driven 30km after I installed them shocks.
You can buy assister springs that are designed to fit between the coil and the cup and hold it in place when the suspension is in droop. Do a search for them.
