dormy72 said:2.25 Gaz coil overs fitted this afternoon, small modification but otherwise ok, unfortunately there was no way the adjustable spring plates were going to fit as broached socket appears smaller than torsion bar, in this case 71-79 items don't seem to fit 72 crossover so more investigation work needed.
dormy72 said:dormy72 said:2.25 Gaz coil overs fitted this afternoon, small modification but otherwise ok, unfortunately there was no way the adjustable spring plates were going to fit as broached socket appears smaller than torsion bar, in this case 71-79 items don't seem to fit 72 crossover so more investigation work needed.
Done a bit more investigating and on counting the splines all 48 of them, it would appear my adjustable spring plates are for pre crossover ie early bays and not late as I need 52 splines which are also slightly larger diameter bars.
So looks like I will be posting an add in for sale section for these soon.
waltz19 said:Hi guys
I have been following this thread and I am just about to order a set, BUT can somebody please
take a measurement from the arch lip to the ground, ( with these fitted )
WHY because I have a steep drive and a low garage door ( too high and it would not fit in the
garage too low and I can't get in the drive!!! )
Thanks Alan
67westy said:I would say more clicks should sort you out, that handles the rebound. Winding up the spring might help but it's more for the ride height but it would also reduce the travel
Mark6455 said:Cool looking good
Did you have any clearance issues regarding shocks against the beam or is it cos mine is 4" narrowed?
Mark
Mark6455 said:Here's mine
I had to raise it an inch![]()
