Thanks everyone,it was great to make progress especially with the chassis and front end.
After getting the chassis done I was considering my options for the front panel etc.It was rotten around the windscreen inner and outer,the lower inner and outer valence was rotten away,both lower A pillars rotten also.As well as a big dent in the front.I forgot to mention that the front had been in a minor accident denting the lower front and wrecking the bumper.The spare wheel on the front didn't help,that was probably why it went so rusty and was off the road.
Anyway I could either buy new stuff,which I could see would be expensive,difficult and the parts didn't seem good quality of what was available.So I sourced a complete front cut from G'day Kombis from a 1969 Aussie single cab.This single cab had had a very heavy T-bone accident.Anyway my gain.So I carefully measured and supported everything then removed all the dash connections handbrake,heater, gear linkages,wiring loom etc etc.Then cut a section of skin going over the A pillars on both sides,cut the A pillars off,the floor pan,front wheel arches and chassis etc (a lot of it just fell off).Then I had to prepare the new front to go on,it needed a small bit of welding on the edge of windscreen a couple of small dents sorted and the lower inner valence repairing.Also had to remove the unneeded floor pan,wheel arch bits and chassis bits where it was cut off.I chose the place where to join the A pillars and made the joint in a staggered way for more strength in the join.Then it was a matter of offering the new front end up,tack welding the front on and checking measurements etc.Once all was ok just weld it on fully.It was a big relief getting that bit done! Forgot to mention,I was going to use the dash off the 1969 front,but I found the wiring was different with the fusebox in a different place so had to swap everything over too! Why did they make so many changes in the '68-'72 early bays?
New front end from an Australian donor van!
Now that is what I call air conditioning!
Repairing the lower inner valence
Thats the front skin off one side
Make pillar joints staggered for more strength
Looks a bit better here,we're making progress at last!
