Running HOT!
Status
Not open for further replies.
Mr_Dib
Nov 15, 2012
11
Hi guys!
Been working my way through my 71 panel, replaced cracked heads, set all my clearances, new points, leads, plugs & coil... But he was still running hot (hot dipstick & also very hot inlet manifolds)
Did 50 miles on a hot day and it maintained temp, just a hotter than 'normal' (on other people's busses)
Thought it might be the oil cooler, changed that, still hot, so now I'm wondering if its
A, the generator/fan (on the last engine pull I noticed the didn't seem to be perfectly seated, there might be some friction on the fan, possibly?
B I've got an aftermarket exhaust on there and the previous ovner has butchered up the tinware to get it in... There's quite a lot of bare pipe work with the exhaust box virtually outside of the body, could it just be a whole lot of heat from this?
C I'm missing the rear lower 1/4 sections of tinware but can this really make a difference?
Has anyone had problems similar to this? Really thought the oil cooler would solve it ... Am I overlooking something obvious?
Cheers for your help with this one!
Dibs
Every piece of tinware is there for a reason. If parts are missing/cut the cooling system will not work correctly. :D
Thanks guys, post moved & yes need to get all correct tinware in there, just concerned its a deeper issue. Cheers for the advice.
Status
