Regained a bit of enthusiasm today, and had another go at the front panel. Rubbed back again and another skim of filler.
However, I fitted a new upper front panel to the bus and this has a different size opening for the front grille. :evil:
A couple of hours later and some reconstructive surgery......
Doesn't look too bad......
A bit more fine wet and dry and a coat of primer.
Needs a bit more work, I think, there's a high spot under the n/s side of the grille that I need to knock back.
Brought the enthusiasm home and started on the front bumper. There's even filler on this :roll:
Might need to get another o/s side step, but other than that it's not too bad. Can't get the bolts undone so I'll be buying some new ones at Bristol next weekend.
