Right then, up early this morning to crack on with getting the gearbox and engine back in.
New fuel pipe and filter and got the cut-off solenoid fitted.
Gearbox went straight back in...
...although I had to turn the shiftrod through 180 degrees to get the rear coupler to line up. Whilst doing this I had to give the rod a bit of a push from the front of the bus. It moved quite suddenly after putting a bit of force into it, and my thumb went through the hole in the chassis along with the shiftrod. The hole is just big enough for the rod, so have removed the top of my thumb. :shock:
Couldn't take a pic of the actual damage 'cos the blood was making a bit of a mess. :lol:
Engine next, and got it lined up exactly and on it went....
No it didn't, got the wrong clutch pressure plate fitted. Another cock-up, and waste of a day. I'll have to get the correct one on Monday and try to get the engine in and running Monday night.
OktoberFest is looming rather quickly.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
