Mr1ncognit0
Hi Guys,
Some of you may have seen my build thread http://forum.earlybay.com/viewtopic.php?f=2&t=57233 but as I am about to start building / sourcing parts for my engine I thought it prudent to start an Engine Build Thread. I will be asking technical questions and posting my discoveries on here.
What started as a strip down and clean, has ended up looking more like a full rebuild and replace of parts. As a result of one of my big ends going and wobbling the hell out my crank shaft and cams I am now in a position where I am looking to replace them. The engine is a 1.6 at present and I wondering whether now is the time to start hunting down a better crank and pistons and cylinder heads and building a bigger engine so I am not chugging around the country side and sweating at the sight of small inclines.
Things I have that I won't be replacing, unless there is a very good argument to do so... you know.... the kind that I can convince the wife of...:
- Engine Block
- Pistons
- Cylinder Pots
- Valves
- Cylinder Heads
- Weber twin Choke Carb 34/36 I think...? The top mounted one.
The rest is a wish list and I am open to suggestions, assuming a budget of circa £750.... what would you guys buy to fill in the blanks?? (not including exhaust). I am not looking for a street racer but something which is not going to be a labour, but also retains the reliability <---- Obviously depends on how well i put them all together!
Any advice gratefully received, mulled over, researched and then acted upon.... followed by wrench time, tears, blood and smiles!
Steve
- Engine Block
- Pistons
- Cylinder Pots
- Valves
- Cylinder Heads
Steve
