mylesbaldwin
Ordered the CORRECT handbrake cables this time and some front flexy brake hoses for the front. All brakes will be complete next week
There's no time to waste my friend no time at all! Or no money either :/ haha71dormy said:Mate I leave you for a few hours and you go nuts! Fair play mate.your cracking on![]()
Graham L said:Myles, be careful running 175/65s on the rear is not a great idea, rolling radius is a lot smaller than a standard tyre and your engine will have to work a lot harder to achieve the same speed if you had larger tyres,
Graham L said:If still on 14's then you should nearly stick as close as possible to stock size, 185/80/14 if on 15's then you can go to 185/65/15.
Anything less than this will affect your rolling radius and over rev your engine.
There's an online tyre size calculator, if you do a search for miata tyre size calculator it should come up.
dubscum said:mate i see what you mean about the rear corner :? I also have some nice lower window frames if you want them too
