Tyres / Stance Thread - Lets see what ya runnin!
you could get Mr whitewall to it for you then you can have any tyre you want.
Front:
Stock rims with 185/55/14 tyres
French Slammer 4" narrowed ball joint beam
French Slammer 2.5" dropped spindles
Back:
Stock rims with 185/70/14 tyres
Slamwerks adjustable spring plates.
mister said:
Front:
Back:
Perfick! 8)
Looks awesome. Do you have any side pics please?
mister said:
Front:
Back:
Loving this bus. What have you treated the bodywork with please? I use ankor wax but looking for something new
Jay81 said:
175 55 15 front
185 65 15 rear
There are some cool looking busses in here now :)
In 2012
I started with stock balljoint front with adjusters and stock back. This was on the way to Edition38 2012
165/60/R14 Front
185/65/R14 Back
Then moved to one spline down at the back to go to london leake street.
In 2013
I then fitted a king and link beam 4" narrowed made by the original Slamwerks with transporterhaus spindles and arms.
The rear is running transporterhaus spring plates.
And now in 2014
New wheels running Appliance Pacers
165/50/R15 Front
175/65/R15 Back
Fully adjustable hydraulic suspension front and rear 4 way. Full 6" rear notch and 5" front notch with large tubs.
A5H said:
Around 3" drop on adjusters at the front and adjustable springplates rear. 15" split rims with 185/60/15 front and 195/70/15 rear
Not nearly as low as some, but perfect for me :D
Will these rims be 4 1/2 j? I'm just having a set of split rims powder coated(which are 4,1/2j) and are they ok with the 195's on the rears ? Both theses fronts and backs are the sizes I'm wanting on mine 8)
couldn't bring myself to slam the bus plus just too expensive but couldn't put up with stock height any longer so.....
cut and turn front beam 2 1/2" drop on front left the rear as it had sagged a bit gas adjustable shocks on front total cost £250
stock rims and tyres
Handles like a dream
2" k&l beam with drop spindles
Rear adjustable springplates
Front 165 50 15
Rear 175 65 15
Tubs to come and rear to go down another inch
Transportehaus:
4.5" Narrowed fully adjustable caster K&L front beam.
3 & 1/2 Inch drop spindles.
Rear adjustable spring plates.
KYB shocks.
Randar RDW 4.5 & 5.5 15" wheels.
Bridgestone slam tyres.
Front is notched, rears to follow.
Whitewall 195/75/14s all round with Plymouth hub caps.
Adjusters in the front beam turned about half way.
Slamwerks adj spring plates rear.
I have a set of Empi 5s but with 185/65 tyres there was a small amount of rubbing so I wasn't sure if they come with different ET's?
