ground hugger
boarder69 said:hello i'm from holland and i run a '68 early bay and like it very mutch.
Its lowerd by adjusters in the front and is not narrowed, and 2 splines in the back. Tires on front are 165-80-14 and i the back 185-80-14. Would like to put 165-65-14 on front to drop a little more
Hi Boarder69
I wouldn't put the 65s on it looks just right.I put a set of 175/65/14s on mine and the tyre to arch clearance is vast,and it makes you want to go lower .they make the van go lower by 30mm if I remember right,but also give you an extra 30mm tyre to arch clearance
and being fully down on the adjusters,theres nothing you can do about the
gaping void only Dropped spindles
