So, the supplier sent the wrong hub bearing seals again. In actual fact, they sent exactly the same seals as the two that are the wrong size. I sent them inner and outer od measurements and pictures, but apparently they don't open boxes and measure parts.
Back to sorting boxes while the roof is repaired.
Found the engine hatch hinges, so test fitted that.
Not a bad paint match after another go with the cutting compound.
Hinges painted. Not going to fit the hatch for the time being as it'll be in the way when I start the rear end.
The box the hinges were in also contained this.
