What's your 4th and final drive?
I'm running 70 @ 3200 on 195/70/15
.82 & 4.57What's your 4th and final drive?
Been there a few times with Steve, Sparky & the Gang
It’s usually just after there Wraggles falls asleepBeen there a few times with Steve, Sparky & the Gang![]()
, Dulle Griet or something like that its called
Here's a couple more for you
A bit of sunshine and the boy's back in his vest
Don’t need sunshine to wear thatA bit of sunshine and the boy's back in his vest![]()
2 filters and 2 fuel systems@K@rlos So that’s a separate filter going into each carb?
As well as the ‘regular’ fuel filter?
Wow!2 filters and 2 fuel systems
1st is this filter that is inline before the Holley ‘red’ fuel pump and feeds the carbs through a Holley ‘red’ pressure regulator as normal
2nd filter (same sort) is before a Walbro GSL392 fuel injection pump which delivers the supplementary fuel for the nitrous wet system at a regulated 35psi via an EFI pressure regulator with a return line back into the tank.
Yeah I’ve made a simple engine very complicatedWow!
That sounds far more involved than I need to be for my twin 40s!
