5erge
K@rlos said:![]()
2110 Specs:
Built by Hector Howe (back street hero) :lol:
Genuine AS41 case
CSP 1.5L deep sump
CB performance 82mm chromoly crank with Chevy journals
CB chromoly head studs
DRD racing 5.4 H-beam rods
Mahle 90.5 pistons & barrels, lightened & balanced
DRD racing L5 CNC ported heads (perfected by Hector) 53cc chambers, stainless steel 40x35.5 valves & dual springs
Weber 48IDF's with veloctiy stacks and CB Performance filters
Facet electric fuel pump
Pressure regulator
CSP intake manifolds match ported
CSP bell crank throttle linkage
Engle FK8 camshaft
Scat lightweight lifters
Scat straight cut cam gears
Gene Berg pushrods
Fast fab spring loaded pushrod tubes
Bugpack 1.4:1 rockers
Gene Berg equaliser pulley
Gene Berg 30mm oil pump/ Berg full flow cover
Stateside tuning flywheel (OG VW core)
Gene Berg race fan
Kennedy stage 2 clutch pressure palte
Super Dalkin friction plate
External oil filter and oil cooler with scoop
Complete bottom end dynamically balanced together.
OG Bosch 009 dizzy, Petronix electronic ignition, Petronix 8mm HT leads, Bosch Coil
Gene Berg 1 5/8 merged header with a ceramic Bugpack mondo muffler
Great spec, all the right bits 8) Makes my 1914cc look weedy.
Des
