graysummers
- Joined
- Jun 16, 2009
- Messages
- 470
- Reaction score
- 15
- Year of Your Van(s)
- 1972
- Van Type
- Crossover
Anyone know if you should be able to see the accelerator cable metal guide tube that goes through the fan shroud and firewall poking out underneath the bus chassis? I’ve been underneath and all I can see is the flexi hose that goes over the gear box. It goes right up to the metal and then you see nowt. I’ve been trying to replace the accelerator cable and can only get to the end of the flexi hose. After that? Blockage which doesn’t allow the cable to go further into the engine compartment. The old tube I removed is shorter than the new one I’ve just bought. I’m wondering if it’s a bit Heath Robinson and the flexi is located a bit more closer to the engine and now causing huge problems.
