Eeza
They say a picture paints a thousand words so here goes: I am adjusting my carb after rebuilding it over the weekend :mrgreen:
The first setting in the process is to set the idle speed now before you do this you must set the actuator in the right place on the CAM (I think)
I have read a lot about setting up and some say set it against the last step ?? Now as I see it there is a Number of steps that drop down onto the cam in the picture. I think that the adjustment is made when the adjuster Pin is touching the CAM and not the Step if you know what I mean The Cam is being pointed at in the picture and identifies the adjuster as 1
From Rob and Dave's Historic Site :
With the choke held in the full open position (stepped cam at its lowest point), place a piece of notebook paper or a 0.003" feeler gauge between the lowest step of the choke fast idle cam the the Fast Idle Adjuster screw.
Slowly turn the screw in until you feel drag on the paper or the feeler gauge. Then remove the paper or feeler gauge and turn the screw in preciselly 1/2 turn - no more! This sets the throttle butterfly open the required 0.004", so you can use the Bypass Screw (read on) to set the idle speed correctly. From this point on, leave the Fast Idle Adjuster screw alone.
(stepped cam at its lowest point) Does this mean the CAM or the STEP doh
