cunning plan
- Joined
- Jul 15, 2008
- Messages
- 2,625
- Reaction score
- 1
- Location
- Northamptonshire
- Year of Your Van(s)
- 1968
- Van Type
- Clipper / Microbus
Please could someone confirm if my understanding / measurement is correct?
I read that the end float needs to be between 3 to 5 thousands or 0.0762 - 0.127mm.
The Dial Test Indicator I have is in mm.
After adding various shims, I have got the end float to measure between the two red triangles as I make the first 'notch' 0.1mm and each notch going up at that point by 0.1mm until 1mm.
1. Is my measurement understanding correct (I've not attempted to measure something with such a small measurement unit before).
2. Is the end float set correctly?
:sign0009:
:sign0009:
