Bit more done over the past few days, in bettween parenting, new baby arrived on Sat morning, last week.
So, fridge up first:
Corked the door inner for the fridge
Had the fridge running, cools well, too well in fact, had to turn it down, had 0C in fridge and this in the freezer!
My leisure battery is a little flat, with around 12.3 static, i had the inverter and soldering iron on for some time, and running up propex and fridge and generall fiddling around, it's on about 11.8, so really need to charge it up before we go away. When engine is running there is 13.3V at the fridge power cables, so the split charge is running ok, though would take a while as there isn't much juice in the leisure battery left.
I also redid the earth supply cable on the leisure battery, and will redo all the red power lead to and from the split charge relay to something akin to the fridge wiring.
Here is the wiring i am using. The thin guage is the original fridge wiring, with tinned ends, and the thick stuff has a direct fused feed from the leisure battery under the bed and floor up to the bulkhead bottom and out to the right of the gas pipes.
Solved the problem of the thick and thin wiring by using a 30A connector with the thick cable twised and fitted one end, along with the fridge wiring fitted into a small red bullet crimp connector, again screwed into the connector block
Finished. I used this connector as it works well, and allows me to have a voltage test point should I need to. I have more connector block, sp could use this method for other items such as LED lights etc, or I could use the 7 core 0.75mm wire i have already run under the floor on both sides of the van for leds, via the fuse box under the bed which has 6 fuses which are currently powering the propex and inverter.
One i did notice on tests was a very slight voltage drop of approx 0.10V from leisure battery to the fridge input on the connector block, I guess this isn't much to worry about??? The cable run is about 5m.
Prepaired the top of the sink unit so that the new worktop would sit flush. Cut back, all sitting flush now.
Worktop fitted, angled brackets doubled for strengh on all corners, along with the same double brackets on the front of the carcass, and on the lower corners in the base to reduce flex, as the main structure hasn't the glued in top and front anymore. Hob is placed cental in the worktop, but with offset to the left on top of the unit, to allow for plenty of clearence when you are reaching down to open the door
How as the hob is originally designed for a domestic enviroment with a standard thickness worktop, i made up so small blocks to enable the hob to sit down flush, there is only a 1mm gap, i will run and smooth off this with black silicone as i didnt like the gap left by the foam seal, which is only a water splash seal, i dont intend on leaking water all over the worktop, so a silicone edge with be a neater solution.
Gas pipe connected. I had a connector which was supplied with the hob, soldered onto the 8mm copper i am using by a very kind member of out local VW group, North Devon VW Club, cheers Caveman, job well done, easy for a fridge engineer with oxy-acetalene power!
Bent and adjusted so the copper and flexi moves clear of the threaded bracket, fitted proper connection, gas ptfe tap and leak tested all joints. Jets changed to lpg. Copper pipe clipped to wood with p clip.
This is the clearance at the rear. Now the thin wood piece which normally sits at the rear of the unit against the bulkhead under the sink top has been removed, and it still retains the half partition in the pull down drawer. Ventillation should be ok. I had also opened up the hole the sink drain went through, so there is additional cool air available just slightly under the rear of the fridge at the compressor side, though the floor into the bellypans and out. Standard westy hole. I'll fit a small drain for the fridge defrost water at a later date down this hole as i ran out of time, and it was raining harder too. :roll:
Sorted
And finally, I replaced the US spec rear lights for new repro units, along with new seals from WCM.
Here you can see the differance. I have some chrome paint, but the rain was coming.... The right hand side is the brake light, and the left is normal side lights. I have also fitted LED rear bulbs, with 136 SMD's in each bulb, much better, shouldn't have to bother with replacing these for a while.
More to follow........
Cheers!
Alistair
