Hi!
I have fitted a new 3 way gas manifold, as i have run one feed off to the propex, another to the gas hob which i am fitting in the westy sink unit, and another feed for a gas bbq with quick release fittings. I also bought a pipe cutter, and re did all the pipes to a chamfered edge., and have used gas ptfe tape on all joints, and will leak test with detection fluid that i have, just need to ptfe the propex fittings, but i think they are gas tight, but belt and braces.
I will fit the quick disconnect on the final gas tap, and the pipe i have is about 2 meters, with a connector in the middle. I would like a actual gas socket for the bbq, but didnt want to cut any holes in the furniture, so the flexi can coil under the buddy seat. Here is what i have used:
http://www.ebay.co.uk/itm/QUICK-RELEASE-COUPLER-8mm-HOSE-GAS-LPG-BBQ-CAMPING-/200640486754#ht_500wt_715" onclick="window.open(this.href);return false;
The gas bottle sits well, and the seat base just closes. I still have some more gas fittings to get for the bbq, as i ran our of this type:
http://www.ebay.co.uk/itm/Caravan-Motorhome-8mm-Copper-Gas-Compression-Nozzle-/250989613735?_trksid=p4340.m185&_trkparms=algo%3DDLSL%252BSIC.NPJS%26its%3DI%26itu%3DUCI%252BUA%26otn%3D10%26pmod%3D260867388849%252B260867388849%26po%3D%26ps%3D63%26clkid%3D7371817012005866212#ht_1508wt_861" onclick="window.open(this.href);return false;
This is the one that the flexi hose it connected to from the gas bottle. I still have to fix the gas manifold to the rear seat bulkhead, and buy some P clips for the flexi hose to secure to the inner seat area, i have some p clips for the gas pipe, but have run this under the floor, so didnt use them. I think i will also get a strap to secure the gas bottle to the inside to save it sliding about, so a little bit more, and i will be done here.
Here is the install under the bed, mine is the other way round to use, as i wanted to minimise the gas pipe run. I have used some foam type seal around the main hole, just as a "stopper" so when i fill the external hole underneath it doesnt go all over the inside as the foam will act as a dam. The foam is just on the edge, the pipes in the middle, so the silicon will be fine here
I have yet to properly secure the inlet and exhaust pipes, will do this once sealed up the holes above. The exhaust is going to the opposite side to the sliding door and vice versa.
Adittionally, i also have a carbon monoxide detector, which is battery powered like a smoke alarm, this will go under the bed to sit with the propex
I intend to make up some wood to cover the inside area where the drop down door is, this is to fit the propex vents, and also the Zig unit, consumer unit and the inverter (you can see the inverter already to one side) Additionally I have a backlit digital battery monitor which i will connect via the zig to monitor the battery voltage.
So, on the front of the panel, once you have dropped the door down, (which will be removable when i find my spare hinges) will be the propex vents, battery monitor, zig unit and the double power sockets, one for actual 240, and the other for 240 via the inverter.
I still have loads of other gas fitting, reel of pipe, clips, gas tap etc, so there will be a for sale thread soon! :msn4:
The wardrobe has been repaired at the bottom, I'm no carpenter, so not perfect, but strengthen the area, and is more solid than before. Managed to do this with out damage to the large side panels laminate, the rear laminate was already damaged, and the wood rotten, and i have a little more work to do on the rear panel where the laminate was missing, for the time being, will redo this area to match the roof and kick panels and will follow on the theme when i fit the zig unit and propex vents etc. I will look for some 2nd hand laminate at a later date and redo it better.
I have bought some special hinges, and intend to mod the westy sink unit to enable it to move out, so i can cook outside, though i may have another plan regarding the hinges.
Now, if i get time (and money), I will be removing the original water container and fitting a compressor fridge in - just need to measure up when i am fitting the hob and grill.
More pictures up over the weekend when i hope to finish off a bit more, and get the wardrobe back in.
Cheers!
Alistair
