Ignition issues!?
Matt84
Jul 26, 2010
206
18
Halesowen, West Midlands
The last few times I go to start my bus, I turn the key, the oil and gen lights come on, the just a 'click ' not a repetitive one like it's trying to start, just a single. I take the key out, give it another couple of go's and eventually fired up as normal.
I've had a look at the starter, the contacts were a little corroded so cleaned them up but to no avail. I'm guessing next step is the ignition switch?
It looks like a spiders nest behind there so was a little reluctant to take apart!
Any ideas about what I should be looking for or even where I should be looking??
Thanks - leccy gremlins are the worst!!
The click is the sound of the starter solenoid trying to engage - I would say that it is not always making it fully home and completing the circuit. Whip the starter out and get it rebuilt / buy new and you should be sorted.
We had exactly the same problem
Could be a worn ignition switch. We changed ours but still the same
Changed solenoid. Still the same
Then mechanic fitted a hot start relay and an additional earth - Bingo. Starts on the nail every time.
