AndyO
Happy Summer All,
Got a bit of a head scratcher, she's running well in the most part but I have this very annoying intermittent hesitation. I can't seem to force it by high revs, low revs, fast / slow, hot / cold, it's random. If pushed, one hot, I would say after slowing down, second gear and pull off it's more likely to happen.
TYPE 4 Engine 1800 twin Dellorto DRLA 40's
In the last 18 months:
Plugs, Leads, Fuel Pump (rotary correct pressure) new elec ignition, float heights, timing, valve gaps.
I've got a coupe of coils / dissy caps and rotors as spares, I checked the resistance on both coils last year and they seem good. Fresh fuel (Shell premium) after a lay up - also tried an additive to rid the ethanol makes no difference.
I had a good go at balancing and setting the mixtures on the carbs last year and plan on doing that again when time allows, but am unsure if rich / lean or unbalanced condition would cause this.....help!
