OK - Got some new pictures as some work has been carried out - will let the pictures do most of the talking:
Offside repair panel (in front of the arch)
Underneath, looking at the rear jacking point and inner sill
Outside sill plug welded in at the bottom and welded at the top on the offside
Offside B-post and outer sill
Offside floor now plug welded and spot welded in
Another view of the offside floor
Lower outer panel (new inside panel already done so no pic!)
Lower out panel , near side (needs the door taking off so it can be folded over and welded etc)
View of the nearside floor
View of the offside outer sill from the inside
Another view of the outer sill
Near side inner sill
Another view of the near side inner sill
Nearside dogleg (under the front passenger floor)
Nearside inner arch - the front beam
Off side dogleg (can see a bit of the new inner front panel)
View of the beam
Close-up of the front
Another view of the new floor
So - to do - little bits to be made to fill gaps.
Rear splash panel in the off side.
Replace panel before the rear arch and splash panel on the near side.
Finish off the front panel.
Seam the joints and install the cargo floor.
Sure there are a few bits I have missed.
Then new brake pipes, ball joints and shocks - fit new headlights then off for MOT :shock:
The way this project has been going, probably another 6 months
