Progress Pics - Dormobile X-Over
woz said:
gninnam said:
cunning plan said:
What googles do you use? Are they the full wrap-around ones or more like glasses?
Full wrap ones - I didn't have them very tight so this, I assume, is how something got in.
After waiting for around 2 hours, got seen - took the object out, looked to be less than 1 mm but the pain.
Hopefully, after a few days it should be back to normal.
Glad you got that sorted! Bet you tighten the strap now.
True :msn4:
Having them too loose will allow something to get into them, but there are other possibilities such as a piece on your hand or hair when you are taking them off, then putting them back on, or something falling into the vent holes that are there to prevent them misting up, which could happen when you are looking down at the floor, then look back up. :? :(
Also, when not in use, even whilst you are taking a 5 minute break, do you leave the goggles up-side-down? That could allow something to fall into them, which then goes straight on your face when you put them back on.
Glad you're alright buddy. :party0047:
All good now thanks - worked on the van today (no pics) so had them even tighter today and no issues ;)
Spent today cutting out some rust on the inside of the arch then putting a new piece in.
Will grind back the welds and seam seal then flash some primer over etc.... but busy for the next few days.
Nice working in the sun and warmth today!
Great work Andy definitely getting there and your going to be on the road this year 8) truely inspirational
Thanks Nick :)
Hoping too but probably near the end of the year....
02.04.2016
Last week I took delivery of a pair of hub/brakes/axle - hope to use all of the parts as they seem to be in good condition :)
A few pics
Got the axle nut off the first one OK
But not the second one as my whacker tool gave up the ghost :(
Oh and almost finished one end of the nearside rear tub. Just need to order the closing panel at the rear and weld in then start on the other side - a few pics (not exciting at all ;) )
snow_pikey said:
Seriously tight, hope you didn't go flying when it broke :shock:
Fortunately not but the air was very blue.
Ordered another one so will see how long this one lasts :D
12.04.2016
Took delivery of some goodies, but made a ****oo - ordered 8mm engine studs, but should of ordered 10mm :(
Was hoping to start rebuilding the engine but will have to wait a bit now!
14.04.2016
Got the closing panel for the nearside rear tub, so prepared it then tacked in:
Then fabricated a bit to go between the splash guard and the inside of the tub:
Plus, a cheeky pic of the van :)
17.04.2016
Closed off the offside tub repair :
Started to grind back the welds and will then treat with anti-rust stuff and a bit of filler and what-not.
These are the last of the repairs (welding wise) to be done at the rear - just need to remove the remainder of the underseal!
25.04.2016
Struggled to get the brake drum off of the hub but got their in the end :)
Bit disappointed with the backing plate as was hoping it was salvageable but was foobared where it was touching the hub - never mind....
26.04.2016
Got the stub axle out of the hub and got it cleaned up!
What's left of the hub:
This is the axle with some anti rust stuff splashed on - tomorrow I will tickle some paint on it then the rebuild can commence :)
gninnam said:
25.04.2016
They are a bitch to get out aren't they!
The spindles look in great condition though! I do not think that has been apart many times, if at all. :D
cunning plan said:
gninnam said:
25.04.2016
It is and like you say, don't think these have ever been off !
27.04.2016
Put a coat of paint on the new axle so while that is drying started building the hub.
Heres what I started with.
Inner bearing installed:
Circlip in:
Grease seal now in :):
Outer bearing, spacer and grease seal installed:
Axle in:
One down, one to go - might be Friday when I get the other side done.
28.04.2016
Other side done :)
Inside bearing and seal:
Outside bearing, seal and started to push the axle through:
The pair together:
Started to assemble the drive shafts:
That will be it for a few days as I will need the boot clips
Got mine to do at some point, some good work there pal, will look real good when all together
30.04.2016
Finished off the drive shafts :)
New piston rings installed - will give this pair another cleaning:
Bling!!
First pair installed.
Adjustable pushrod tubes ready and waiting:
But - wanted to fit the head, but I forgot it had a stuck exhaust stud so thought I would remove this first.
Welded a nut to it:
And.... the nut came off :(
Welded 3 more nuts and all came off.
So got a larger nut and welded this on - but it broke off more stud.
Will have to get it drilled out I think :(
06.05.2016
Continued to tidy up the rear inner arch tub area and the nearside is almost complete - here it is with some red primer on:
Started on the offside rear tub, this is the rear section with red primer on:
