Not really Brett, the new bench seat (almost) matches the cab seats and isn't falling apart, unlike the existing one with the mexican blanket cover.....
King and linkpin beam for the fitting of.
madness said:looking good dude wot happened to the brm,s
Something in the catch has worn - it simply cannot physically (in engineering terms) techincally be the seal. It can't! A new springy seal may though the problem into the spotlight, but it's not the seal's fault.sparkywig said:I know Steve, the hinge is as far back as it will go, so without elongating the holes it stays where it is (need a new slider anyway....).
The problem is the new seal though, with the old seal I still had a couple of mm adjustment and the door had even shut lines when closed. With the new seal it doesn't shut far enough forward and sits proud of the bodywork because I've had to reposition both the front and back keepers to get it to latch.
You would've thought after all these years I'd be used to ill-fitting parts but it still pisses me off, and it wasn't a cheap seal.
sparkywig said:
All I need now is ozziedog's full width Westfalia bed and I can get on and fit the interior out.
