I've had too much grief with the rear brakes to worry about centre caps at the moment, Mycha.
Anyway, new master cylinder fitted and I still have no brakes. It did need changing though as it was leaking though the seals.
Spent most of today bleeding the brakes, changing pipes around on the master cylinder and then bleeding them again. Still no pedal and rear brakes.....
Until about 4.30, when the thought occurred of undoing the callipers from the carrier, packing the piston and then bleeding them with the bleed nipple as high as the flexible pipe would allow.
Bingo, loads of air removed and I can stop.
Handbrake connected and now just waiting for the hub nut spacers to arrive, and then I can drive home.
