* Reserved for reply after the morning's priority work *
EDIT: Right, I can reply with more detail now.
What did I miss, where did the Brazilian bus come from? :? :|
Buss69 said:
For the rear I'm going for a set of Transporter Haus adjustable spring plates with Red9 Rear disc set-up. Does anyone out there have any experience with this set-up on the rear?
Yes, I have experience with the TPH Adjustable Spring-Plates, but not the disc setup. About half-way down this post is where I begin the install if you want to refresh your memory:
http://forum.earlybay.com/viewtopic.php?p=435238#p435238" onclick="window.open(this.href);return false;
Buss69 said:
I know I'm not the only person to have done this :lol: but I have a couple of questions. What has everyone else done when removing the bearing housing. The 4 22mm bolts look pretty hardcore i'm sure brut force id going to be the way but are there any tips out there?
They are actually pretty trouble-free as they are such a nice chunky bolt and thread, they should not be seized and require all the hassle of drilling etc. Just get a good breaker bar and a 1/2" extension, keep it straight on the bolt with one hand and give it a couple of bounces with the other.
Buss69 said:
What has everyone else done when fitting adjustable spring plates with regard to fine tuning the adjustment of the bearing housing and ensuring it's the same as before removal? Has everyone taken their bus to have the rear wheels aligned and adjusted. it's not something I've read much about? Any advise here guys would be very helpful.
The biggest tip I can give you is to measure the end of the current spring plate to a reference point on the chassis. This way, when you put your TPH ARSPs (teehehe arsp...) on, you will know where to set the plate up in its 'highest' position (presuming the bus is currently stock height).
I did not do this, so when I came to put the ARSPs on, I had no idea where stock height was, or even where the old lowered position was. So I had to take measurements from the Bentley manual to set the ARSPs in what I hope is the stock-height position, at their 'highest' setting. However, you get a drop of 1.5" (IIRC) from ARSPs even before you begin to adjust them.
Hope that helps a bit buddy!
