Trikky2
Thanks for the explanation Alex. Makes a bit more sense now. Glad I did mine when I did.
Bluesnailman said:I'm no expert in this but have stated asking myself the same question. I found this the other week.
http://www.aircooled.net/1800cc-vw-engine-no-machine-combo/" onclick="window.open(this.href);return false;
Must be plenty of opinions out there (yes, I know it wont be as good as a £5k engine, but how does it compare to stock?). Hope this isn't seen as a thread hijack - intended to take it forward
rlepecha said:Alex VW Heritage said:Exhaust wise the VS is the cheapest stainless system you can get so you get the longevity out of it but yes your cirrect you can get a good flowing system for around the £100 mark if you go for mild steel.
If you have a local custom exhaust maker you might be able to get a stainless exhaust made up for less than the vintage speed one. Mine was £280 fitted, so worth a look if you want something different from the norm.
Yes you can build a SP 1641, I have one in my bug with twin 34's and an Engle 110 cam. I match ported the heads and cleaned up all the burrs to help it flow and on the dyno it pulled 70bhp, I can't remember what jets ended up going in though. I am going to rebuild its as a TP next time and full flow it. I will then try it in the bus!!Dickie524 said:Right guys, sorry to go round in circles but I *think* we are homing in on a decision...
I reckon I want to be able to use the bus this year, rather than chase engine perfection in the first season and with my first bus. So I thought we'd go for something relatively simple to kick things off - minimisng outlay but still replacing the heap that's in there... and as such, I reckon a 1641cc, keeping as much original hardware as possible, such as the 1641TP offered from VW Engine Company. However i DO still fancy twin carbs, so, given the constraints, what would be the reccomendation for a reasonably lively combination with one eye still on the budget? Twin Weber 34's? Or a little more?
Also - again apologies the 'newbie' question - is 1641cc single port possible? I've heard SP's are torqier for a given volume...
At the moment we are very short of time so unfortunately I would probably be looking for some carb combination thing off the shelf, which goes against the grain if anything I have ever done, but time is marching on and we are really keen to get the bus moving this season
Thanks again, Rich
