I finished off the Dizzy blank for my Megajolt instal.
As the MJ does away with the dizzy I could either remove the dizzy drive shaft and washers or use an old dizzy and cut the shaft down. I chose the latter as I can always remove the drive later on and I need to make sure the MJ is up and working before I do that.
I used an old dizzy, stripped it down and cut the centre shaft down. To cap this I used an old garlic dip container from my local Kebab shop, it fits a treat:
I fixed this on the dizzy with epoxy glue:
Then masked it and sprayed it with plastic primer:
Finally I sprayed some satin black top coat on and here it is drying out:
To finish this install off I am waiting for a couple of fittings for the inlet manifolds so I can get the vac signal to the MJ and then it is a case of fitting it and finalizing the loom. The base map is ready and will be tuned once the engine is sorted and run in.
I'll post up a "How to MJ your Bay" along with the suppliers I used and approx costing (it will not be cheap, but I am using quality parts).
