Hi,
I seem to be blessed with a drip from the end of the lobe on my oil filler Neck - 1600 twinport.
The drip occurs both when driving and also if I top the oil up when stationery. After filling if I place a rag under the lobe the drip eventually stops.
Is this a common problem .... any thoughts on a solution?
The oil collects in a small pool in the bottom of the pulley tin ... its not excessive but a bit messy.
Any thoughts much appreciated.
