G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #501 09.07.2015 So - start to look at putting the offside rear quarter on now. Trimming down and trying on for size.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #502 15.07.2015 Decided to mount the battery tray to the chassis leg first then should make lining up the rear quarter a bit better
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #503 And then a trail fit of the rear quarter. It still fits
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #504 20.07.2015 Needed to address an area around the hatch area where the rubber goes before I attach the rear quarter as it was badly rusted (the dark area you see in the channel is old glue..) Lined up the rear quarter.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #505 22.07.2015 Let the battle - sorry, mean welding - commence.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #506 23.07.2015 And yet more
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #507 29.07.2015 Had to leave it for a few days so rust set in So started to grind down the welds and remove the rust.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #508 30.07.2015 Due to having to leave it in the open over night, put some rust prevention stuff on the welds.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #509 01.08.2015 Started the grinding down process. Started to join the wheel well together with the cut.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #510 02.08.2015 Looks like I have added a skim of filler and sprayed some etch primer over it.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #511 03.08.2015 A bit more filler (hate this part)
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #512 06.08.2015 Getting their now.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #513 08.08.2015 Filling and sanding completed so a coat of primer then a top coat.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #514 09.08.2015 Seamed sealed the weld areas on the inside and a dusting of top coat: Oh - and rear light now on
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #515 16.08.2015 Adding in the final piece - horrible piece as it has many curves. The hole from inside the engine bay: From under the wheel arch: The repair piece cut and being tested for final fit:
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #516 29.08.2015 Almost up-to-date now (thank god) Now welded in and the welds ground down. A bit more tidying up then I will paint and seam seal the remainder of this side.
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #517 Oh - and changed my daily driver too. Liking it alot
mike202 Well-known member Supporting Member Joined Sep 3, 2011 Messages 2,592 Reaction score 722 Location Northumberland Sep 2, 2015 #518 I admire your dedication, you'll be on the road next year for sure 8) Nice daily driver!
G gninnam Well-known member Joined Oct 5, 2006 Messages 8,284 Reaction score 118 Sep 2, 2015 #519 mike202 said: I admire your dedication, you'll be on the road next year for sure 8) Nice daily driver! Click to expand... Thanks Mike. Getting there with the welding but still a bit to go before I can get it MOT'd. Agreed, the daily is nice
kevinhall Well-known member Joined Sep 28, 2009 Messages 277 Reaction score 1 Sep 2, 2015 #520 Doing a brilliant job there Andy. Keep it up
