USwesty said:
Hows the build up going fella?
Hi Al, Thanks for asking.been a bit hit and miss lately, not been very well. had a blood clot in my leg and lungs - bit scary!! Anyway,on the mend now
Today I've fitted the trim/scraper around the cab windows.Normally,I'd go for original, if not the best possible quality parts and after a bit of research,it seems even the original VW Brazil cab door trims are poor.What I really wanted was the shiny chrome effect trims.(I never understood why things like door handles and on deluxes,window trim,badge etc was shiney chrome, yet the cab door trim is dull aluminium) So I thought, If they are all crap,might as well have the ones I want.
I've had dealings with these trims before and they are a bitch of a job.They are liable to bend like tin foil :evil: so I decided to do away with the clips and bond them in place,that way I could ensure the trims are equally fixed in place right around the door. What I was aiming for is for the trim to be nice and straight and snug around the door aperture,which I managed to do,so I'm quite pleased with the result...
dry fitted the trim to get the shape right.Applied the tiger seal then held the trim in place with tightly pulled masking tape.....
I let it go off all day, then took the masking tape off and hey presto! I know its not the orthodox method of securing them but I couldn't live with loose or floppy or twisted trim due to man handling those little clips in! and I don't plan on taking them in and out all the time.
Another advantage of using the tiger seal is rust prevention.I've seen loads with the rust coming from under the trim.If I'd have used the supplied metal clips,they push into pre made holes in the door.But....as they snap in place,they take paint off,so you have a situation where you have bare metal around the clip hole, hidden under a trim which due to its close position to the door body,is acting with capillary action to hold water under the trim which runs down to.......yes......the bare metal around the clip = rust.hopefully the tiger seal, (just out of site under the trim) will stop any water creeping under the trim,also no need to chip the paint off around the clip holes as I havn't used them! time will tell if it has worked :|
Results........
For those who are interested, the trims are 'vewib' brand from C&C
The next job is to fit the drop light window. Thanks for looking
