Alternator
Gabs
Jun 1, 2023
222
247
Bristol
1970
T2 a
So I been looking at some options on a new alternator for my bus. Currently alternator went pop but don’t ask how. I reckon it’s a 55 amp alternator but seen a 75 and 90 amp upgrades. What I’m reading just need to make sure wiring good on bus so mine was re-wired about 10 yrs back now.
What’s pro and con’s between 75&90 alternator.
Just go for the cheapest, no point having high output unless you have dozens of electrical/electronics in the van, they also wear belts quicker, trust me I know lol
Worth ringing Bristol Auto Electrical to see what they say about re-winding yours, and Sparx whilst your at it
Unless you're running high output spot lights, or a massive sound system with amps and sub woofers, a standard 55A alternator will be more than adequate.
As Justin says the higher the output the more it wears belts and saps the engines power.
Going to order a new one then may recon mine for a backup. All spares help.
Thanks for the advise makes sence.
Get yourself a 55amp from power lite. Million times better than the generic Chinese ***** the usual suspects all sell.
75 is only required if you’re running lots of additional electrics like gauges, fuel pumps, after market ignition or big stereos etc.
I fitted a JK one when I got home from work today but now can’t get my belt to tighten. all shims are removed but still loose. Are there different sizes ?
Give JK a call. Probably need a new belt
Either way they'll know.
Gauges draw very little power, of which a few are almost essential for the 1968~79 VW Type 2s; especially those with the VW 13/1600 Type 1 Beetle style air-cooled engine, whose cooling system relies upon the integrity & non-slippage of the V-belt and non-seizure of the dynamo or alternator shaft bearings.
If the V-belt breaks or the bearings seize, one needs clear, emphatic warning that the cooling system has FAILED catastrophically and one needs to promptly bring the vehicle to a halt and STOP the engine, before that also seizes or is otherwise severely damaged!
Whilst driving on the M25 motorway in April 1991, I experienced alternator-shaft seizure, of which I was initially warned by illumination of the ignition warning-light, followed by the extremely rapid rise in the cylinder-head temperature gauge reading, which increased by at least 100ºC in the time it took me to coast to a halt on the hard shoulder. The oil-temperature gauge reading had not perceptibly changed.
Smoke was billowing out the high-level air-intake vents, so I gingerly opened the engine-compartment hatch, with Swordsman 1•5 kg BCF fire extinguisher in hand, to be greeted by a collection of charred fragments that had been the V-belt! I received training in their use in the chemistry laboratory at university in 1975 and during a general internal course in 1988 re fires & fire-extinguishers in the Fulmer Yarsley fire-test section. They were still in common use in 1991 by the Army Fire Service - later amalgamated to form the Defense Fire & Rescue Service.
https://en.wikipedia.org/wiki/Army_Fire_Service
https://en.wikipedia.org/wiki/Defence_Fire_and_Rescue_Service
https://www.gov.uk/government/groups/defence-fire-risk-management-organisation
https://hmvf.co.uk/topic/34691-cvrt-scorpionscimitar-fire-extinguishers/
https://www.mig-welding.co.uk/forum/threads/best-car-extinguisher-type.78439/
This was one of several reasons why my father and I chose to upgrade our 1973 VW "1600" Type 2 with a VW 17/1800 Type 4 style hybrid air-cooled engine.
